Timed Call forwarding for Ring Group
Discussion in '3CX Phone System - General' started by nas, Dec 19, 2013.
  1. nas
    nas
    Aug 30, 2012
    5
    Hi. Does anybody know of anyway to call forward calls to a ring group at a specified (one-off) time?
    I have a customer that requires their incoming Ring Group calls to be forwarded to a specified mobile over Xmas. Basically he asks, "Please can our landlines be forwarded to my mobile from 1pm on the 24th until 5.00pm on the 31st". His "landlines" are SIP trunks that connect to a Ring Group in 3Cx. Many thanks. Neil
    10,362
    226
    You could try forwarding the ring group to a newly created extension. Set up forwarding rules for that extension using the Exceptions Tab, where time of day options can can used.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Create phantom extensions, tweak the forwarding i.e. profile status as needed. Set specific office hours for that extension and that will do it. We have the very same situation.
  4. nas
    nas
    Aug 30, 2012
    5
    many thanks leejor and sigma1... sounds like the perfect solution.
    Regards
    Neil
  5. sigma1
    Nov 20, 2009
    542
    Glad we could help! Don't forget that you should supply the person in charge with the Phantom extension and mailbox PIN so that he/she can call in and change the profile as they see fit. Additionally, Matt @ VoipToys has an APP for that too.
