Timer on 3CX calls
Discussion in '3CX Phone System - General' started by manolo-ehc, Nov 5, 2009.
  1. manolo-ehc
    Aug 10, 2009
    Does anybody know if it is possible to set up a timer on extensions config for everycall on 3CX server??
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    A timer that does what? Wakes you up?
    The only available "Timer" that you will find in the extensions page is the one of the Ringing Timeout.
    After an extension has ringed for XX Seconds, the call ends.
    You can find this option in Management Console > Extensions > Ext100 > Forwarding Rules > Ring Timeout.
    Is this the timer you wanted?
  3. manolo-ehc
    Aug 10, 2009
    Thanks,
    what I need is to set up a timer so every call (inbound / outbound ) will not be longer than xx minutes.
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    And do what? Just disconnect the call after a period of time? What if someone is on the phone with 911 and is getting life-saving instructions and you decide to drop the call? Just asking.
