Tip: 3CX services don't start if using WiFi
Discussion in '3CX Phone System - General' started by Bob Denny, Feb 22, 2009.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Don't laugh... Due to the requirement that IIS and 3CX/web run on port 80 (see An error occured in IVR session), I couldn't use the main server system in our small office for 3CX. Instead I put it on another 24x7 system that uses WiFi internet access.
    When that system is rebooted, most 3XC services don't auto-start. I found that the Linksys WMP54GSSVC WiFi access/driver service was not starting quickly enough, and that caused the 3CX services to fail on startup. The solution was to add the WMP54GSSVC service to the dependencies of the 3CX Phone System Database Server service (upon which most other 3CX services depend). For details see the MSKB article How to delay loading of specific services.
    In my specific case, I added the WMP54GSVC service to the dependencies of the 3CX Phone System Database Server service (which already depends on RPC). After that, all 3CX services start successfully on reboot.
  2. inter-rupteur
    Feb 9, 2009
    15
    Hi Bob,
    you can use IIS with port 80 and 3CX/web with port 8080 if you want ! It's not a problem !!! Nothing is closed ! :mrgreen:
    Thanks for this tip !!
    Inter-Rupteur
  3. Bob Denny
    Feb 21, 2009
    131
    Ah, thanks! I didn't want to use the internal webserver because the docs for 3CX say it's only for testing. Well, it's on that other system now and I don't want to move it again :lol: :lol:
    Meanwhile, I guess I don't have the dependencies set quite right yet. My wife backed that system up (TrueImage) and rebooted it. The 3CX didn't come up! I tested it a few times before by rebooting... So when I figure out what additional dependencies I need I'll post here. It may be a few days.
