To accept calls from gateways or ITSP not registered
Discussion in '3CX Phone System - General' started by juanmanuel, Jul 5, 2011.
  1. juanmanuel
    Jul 3, 2011
    Hi:
    It is possible to recieve calls form Gateways or SIP trunks or ITPS wich 3CX is not registered?
    If yes it is possible to drive the calls to extensions with the same number as the DID numbers?
    Juan Acevedo
    email: jacevedo@e-global.com.co
