Solved Today Call Log Disappeared after today update.
Discussion in '3CX Phone System - General' started by AH2, Feb 8, 2018.
Tags:
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Today after installing the latest update on the server I can't see the call history for today calls, only from yesterday and older.... this it's on 2 different servers hosted on GPC.
    Any hints ?
    Thanks,
    AH
  2. AH2
    AH2 New Member
    Mar 14, 2017
    112
    It looks like its related to the time, if I select show yesterday logs, it shows for Feb 06 2018, not Feb 07 2018....
  3. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Yes, that's what I meant by installing the latest update.
  4. kedesignz
    Nov 10, 2014
    12
    5
    Updated to "15.5.8801.3" today (02/08/2018), and we're also experiencing the reported behavior(s).
    - After update, unable to view logs for today's date, 02/08/2018.
    - When clicking "Call Log" without any filters it shows records for 02/07/2018.
    - When applying filter for "Yesterday" it shows records for 02/06/2018.
    Potential bug?
    AH2 likes this.
  5. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    They'll fix that in SP4
    #5 jimbo59, Feb 8, 2018
    jbryant84 and sip.bg like this.
  6. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Probably there won't be SP4, right v.16
    jimbo59 likes this.
  7. kedesignz
    Nov 10, 2014
    12
    5
    Are these public releases not tested for QA?
  8. THCO
    May 16, 2017
    56
    11
    Same issue here, Anyone know of a fix?
  9. kedesignz
    Nov 10, 2014
    12
    5
    THCO,
    I was able to change the server date to the next day 02/09/2018, to view today's (02/08/2018) records.
    However, I wouldn't recommend this as a fix.
  10. kedesignz
    Nov 10, 2014
    12
    5
    Jimbo59,
    Agreed, I am currently rolling back one of our servers.
    I am seeing more issues with SP3 than actual fixes or new features.
  11. AH2
    AH2 New Member
    Mar 14, 2017
    112
    They haven't commented anything so far, so I would guess it's a bug and they'll try to push it asap. I hope :) ..... how can I downgrade ?
    Thanks.
  12. kedesignz
    Nov 10, 2014
    12
    5
    AH2,
    We keep daily backups, for 7 days.
    I am trying to look for a 15.5 SP2 download file or link.
    May rollback to a previous version using a backup.
    I currently have a installer for "15.0.55955.0", if needed.
    AH2 likes this.
  13. sip.bg
    Nov 7, 2016
    704
    219
    Which version for what OS you are looking for ?
  14. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Im running servers on Google Cloud, and have backups taken every night, if I restore to lastnight backup would this downgrade ?
    [​IMG]
    Thanks.
  15. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Yeah it looks like they wanted to do hot testing in the wild, not very smart!
    jimbo59 likes this.
  16. kedesignz
    Nov 10, 2014
    12
    5
    AH2,
    I don't believe so since that is primarily data and configuration files.
    Your will need to reinstall "3CX Phone System" from a previous version, and make sure your backup is for that version.
    I can't speak for Google Cloud, as we currently use Amazon EC2, however the process should be the same I believe.
    I was able to locate the following 3cx Phone System 15.5 SP2 link for Windows.
    http://downloads.3cx.com/downloads/3CXPhoneSystem155.5932.2.exe
    I have the following files if needed:
    3CXPhoneSystem155.5932.2 - Windows
    3CXPhoneSystem155.6354.2 - Windows
    AH2 likes this.
  17. sip.bg
    Nov 7, 2016
    704
    219
    Note that 15.5.5932.2 is SP2 beta version.
    What version and what OS you need ? Send me email (see signature below) or a private message with your email. I will send you a link for wetransfer with file you want.
    #17 sip.bg, Feb 9, 2018
    AH2 likes this.
  18. THCO
    May 16, 2017
    56
    11
    I logged in from a different computer and now call logs are working. So maybe try clearing browser cache to see if that fixes it.
    jimbo59 and kedesignz like this.
  19. kedesignz
    Nov 10, 2014
    12
    5
    sip.bg,
    Thanks for the info; it was from a public release link.
    Is 155.6354.2 a SP2 final release, non-beta; this is what we had previously.
  20. kedesignz
    Nov 10, 2014
    12
    5
    THCO,
    Thanks for that, confirmed working on another PC, different network also.
    Little things that we forget to check.
    I assumed it was similar to the recording issue in the previous build.
    Still going to keep the installers archived in the future.
    jimbo59 likes this.
