Toggle extension login/out
Discussion in 'Call Flow Designer' started by agesen, May 31, 2017.
  1. agesen
    Oct 17, 2016
    18
    Hi all
    Would it be possible to toggle extension login/out of a particular queue through CFD?
    Regards Nanna
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,596
    125
    Hi Nanna,
    You can use the Call Control API from a Launch External Script component, to change an extension to logout from ALL the queues. Here you have the API docs:
    https://www.3cx.com/blog/docs/call-control-api/
    Kind regards.
  3. agesen
    Oct 17, 2016
    18
    Hi Ernesto
    I would like to build a CFD that login/out extensions of a particular queue on a specific time - avoiding doing this manually from the dashboard in windows client.
    Regards Nanna
  4. edossantos
    Jun 27, 2007
    1,596
    125
    The Call Control API is the way to go. The console uses it to update the configuration, so you can use it as well from a CFD app.
