Too many failed logon attempts...
Discussion in '3CX Phone System - General' started by msnyder, Aug 1, 2017.
  1. msnyder
    Jul 20, 2017
    24
    How long is the waiting period to try to login again?
    10,371
    230
    In the 3CX settings, you can choose how long the time-out period is, or how many attempts are required to start the time-out. You don't wan to set it too low, I use 250,000 seconds, and some use longer. A lower setting only encourages hackers if you aren't keeping on top of permanently blocking repeat IP's on a regular basis. I do white-list the local LAN as I have had local devices blocked, at times, for some reason.
  3. msnyder
    Jul 20, 2017
    24
    Where are those setting on Debian?
  4. leejor
    10,371
    230
    It used to be under Settings/Security/Anti-hacking on the Windows versions. As I have yet to try out 3CX Linux, I can't say if it is in the same location or not.
