I would suggest an alternative, go to the PBX Status page, click Blacklisted IPs. If there is already a blacklisted entry for your current IP, make sure to delete it first. Now add a new entry to whitelist your own IP address if you are the admin, so you will never be blacklisted.
For the moment, you will have to log in from another IP address (ie. from your mobile using LTE)
By the way, were you logging in as a user extension with administrator rights, or were you logging in as the global administrator?
it would seem that you are using the wrong password if you keep getting blocked. is this possible?
maybe try rebooting the server, not sure if that will help but it would seem it won't hurt to try
Did you or another admin perhaps enabled Console Restrictions under the PBX Security Settings?
<Parameter>
<Description>Restrict access to specific IP whitelist</Description>
<Name>IP_WHITELIST</Name>
<Type>String</Type>
<Value>["xxx.xxx.xxx.xxx"]</Value>
</Parameter>
If console restrictions were indeed enabled, it will not allow you to connect from anywhere other than the allowed range (i.e the machine's local range).
Open your backup, look in the XML file in the root folder of the backup and search for:
XML:<Parameter> <Description>Restrict access to specific IP whitelist</Description> <Name>IP_WHITELIST</Name> <Type>String</Type> <Value>["xxx.xxx.xxx.xxx"]</Value> </Parameter>
<Parameter>
<Name>IP_WHITELIST_RESTRICTED</Name>
<Type>String</Type>
<Value>1</Value>
</Parameter>
<Parameter>
<Type>String</Type>
<Value>[]</Value>
</Parameter>
Perhaps, there is some internal NAT that makes the traffic appear to come from another subnet as far as the PBX can see.
Regardless, I'm glad to hear it is now resolved
listen [::1]:5001 ssl hhtp2;
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
