too more problems old and new version
Discussion in 'Android' started by guidoling, Sep 16, 2010.
  1. guidoling
    Jul 6, 2010
    5
    old version
    on lg gw620 android 1.5
    prossimity sensor not working, is impossible to stay on the phone without pinching the screen with the 'ear!!! :cry:
    no audio in remote wifi or 3g connetion at the remote 3cx phone system.
    wifi in local system is ok but drain battery
    screen not rotate.
    new version
    crash at the startup of 3cx phone progrram
    on motorola flip-out android 2.1
    now im testing with a vpn connetion but is hard.
    screen not rotate.
    new version but some problems, What happens?
    i think that the 3cx is unusable with the touchscreen telephone
    please not remove the old version from the market especially when they are no longer compatible with previous versions of android
    Best Regards
    G.Guidolin
    La Meccanica srl di Reffo
    Italy
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    - 1.5 is no longer supported. You can use an older version to see if that one works better for you.
    http://www.megaupload.com/?d=43VFZ8OD
    - Having no Audio in remote wifi means that your firewall is blocking the needed services. You will have to configure your router to correctly let audio pass freely. Having no Audio in 3G Mode means that your 3G provider most probably blocks VoIP.
    - This is an issue on ALL Android Phones. Enabling Wifi will significantly decrease your battery life.
    - We still do no have the Screen rotating feature, it's something we will add in the future, but only after we have made sure that people have no more major issues such as the ones you are having right now.
    - I can't comment on this as i've said, Android 1.5 is a very old version and we do not support it anymore.
    You can use this version to get you previously working 3CXPhone back. http://www.megaupload.com/?d=43VFZ8OD
    The same as i've replied in my first post...
    Other than the Screen Rotation issue which is something related to the 3CXPhone, all others are related to external factors.
  3. guidoling
    Jul 6, 2010
    5
    the prossimity sensor not working .
    can you solve the problem :evil:
  4. LeonidasG
    Nov 19, 2008
    1,500
    98
    The proximity sensor may really be an issue with the VoIP Phone.
    We are currently working on most Android issues out there, please be patient until the next release :roll:
