Tool Tip **NEXT UPDATE Xtend Timer
Discussion in '3CX Phone System - General' started by KerryG, May 19, 2011.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The time out on the tool tips has got to be fixed. On some of the longer ones like explanations of the some of fields when setting up multicast paging you don't have time to even read half of it before it disappears. Preferably it wouldn't go away until I moved the mouse again. It is really driving me nuts, I had to do a screen capture just to be able to read some of them.
  2. dab
    dab
    Nov 1, 2009
    67
    Re: Toll Tip Total Frustration
    If there will be a change in tool tips it would be also verry nice if they where multiline, since not everyone is administering their 3CX with a 26" or larger monitor ...
  3. reighnman
    Mar 3, 2011
    12
    Re: Tool Tip Total Frustration
    Totally agree, I end up having to inch the mouse around to fully read the tooltips
  4. smb1
    smb1 New Member
    Mar 18, 2009
    104
    This has been a frustration of mine for a looonnnngggg time.
    +1
  5. FBW
    FBW New Member
    Nov 19, 2008
    108
    I agree it would be nice to be able to read these tips in a more comfortable manner.
  6. matictec
    matictec New Member
    Mar 31, 2008
    188
    +1
  7. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    And now we have it. latest update.
  8. dab
    dab
    Nov 1, 2009
    67
    Re: Tool Tip **IMPLEMENTED
    coo :D when will this update downloadable?
  9. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Sorry DAB - I meant next update. Excuse me.
  10. dab
    dab
    Nov 1, 2009
    67
    thanks for clarification
  11. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Available for download.
  12. KerryG
    Jun 19, 2009
    960
    Not fixed when using Firefox
  13. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Can you try using a different machine using firefox? This is definitely fixed with firefox also - you might have a problem on your machine or browser settings. There is no reason for this simple thing to work on all browsers except your firefox. Delete your browser cache and try again. We tested this on all latest browsers IE, Chrome, Firefox.
  14. dab
    dab
    Nov 1, 2009
    67
    Thanks :) for me it's working in IE8, FF4 and Windows Managment Console.
  15. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Thanks for the confirmation on this.
  16. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    The update doesn’t work for me either
    I have tried Firefox and IE, but the problem stays
    When I move the mouse on the question mark the time out is still much too short to read the explanations.
    I access the Phone System via the Windows Management Console and RDP, but there is no difference.
    Nicky, maybe a “culture problem” ? ;)
  17. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    No I do not think this is a culture problem. i think it is a cache problem. Clear SL cache and browser cache, Let me know with your findings after this. (Thanks for yest btw)
  18. complex1
    Jan 25, 2010
    803
    45
    Hi Nicky,
    Before we misunderstand each other, I refer to the tool tips in the 3CX Phone System.
    I have cleared all cashes in FF4 and IE8 manually and by using CCleaner.
    Sorry, but the problem still exists.
    After, say 5 sec. max, the tool tips are gone.
    To read the tip again, I have to go with my mouse to another question mark, and then go back to the previous one otherwise it won’t pop-up.
  19. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    Do not use CCleaner. Clear cache in the normal standard way using the clearing of cache from within the browser and clear the Silverlight cache as described. Right click silverlight, Application storage, delete all. Confirm that application storage is enabled.
  20. complex1
    Jan 25, 2010
    803
    45
    This is where I am afraid of.
    You and the poster of this thread refer to MyPhone and I refer to the 3CX PBX.
    I don’t have timeout problems with the tool tips in MyPhone, but I have timeout problems with the tool tips in the PBX.
    Sorry for the noise.
