Toshiba Strata PBX Support
KidSquid
Has anyone been able to configure the andrioid client to connect to a Toshiba Strata PBX VOIP port?
If you have...any configurations/suggestions would be greatly appreciated.
Thanks,
Sid
Hey Sid,
Not sure if you figured this out or not. I can get it to connect no problem. My problem is getting it to make external calls. Once you set the audio codec to G.711 uLaw you will be able to make internal calls. When placing an External call you will here it ring for a split second and then it will go silent. The call still goes through yet neither end can hear one another.
-Zack
I am a new user looking for the config on both side:
Toshiba CIX670 w/MIPU & 3CX Ver 1.3.4
Can anyone help?
Getting Started - Admin
Boykins_54
Get 3CX - Absolutely Free!
3CX
