Tracking inbound call
Discussion in 'Call Flow Designer' started by Andrzej Pierscionek, Jul 6, 2017.
  1. Andrzej Pierscionek
    Jul 6, 2017
    14
    I have a following scenario:
    Inbound Call -> VAD call flow A -> queue 1 (if no anwser) -> VAD call flow B -> make magic happen.
    In call flow B I need to make a decision based on session.did. However this information is avalible only in call flow A, and in B this variable is empty.
    How can I pass such information (or content of any variable to make it more general) from call flow A to B when there is a queue in the middle ?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,677
    131
    Hi @Andrzej Pierscionek,
    In order to pass information forward, you need to save that information somewhere (for example in a database), using the "session.callid" as the key. Then, in the call flow B you will be able to retrieve the information from the database using the session.callid, which doesn't change.
    Kind regards.
  3. Andrzej Pierscionek
    Jul 6, 2017
    14
    Thank you.
    I was afraid that might be the case.
    So I'll probably go with database or files.
  4. edossantos
    Jun 27, 2007
    1,677
    131
    Yes, you can use database, files, or whatever you feel more comfortable with. Give it a try and let me know if you have any issue.
