transfer a call with free edition
Discussion in '3CX Phone System - General' started by druid33, Mar 27, 2010.
  1. druid33
    Mar 26, 2010
    its possible to transfer a call with 3CX Phone System for Windows Version 8.0 free edition?
    its possible to connect to 3CX Phone System for Windows Version 8.0 free edition annalog fax and use it to receive a faxes?
    thanks for reply
  2. FBW
    FBW New Member
    Nov 19, 2008
    108
    All features should be (temporarily) possible with the free edition.
    I even think that call transfer remains possible after the free trial period. On the other hand the price for the mini version is not that high, right?
    Youcan't attach a serial fax modem to my knowlegd to receive faxes on 3CX. Sending faxes from 3CX is never possible.
  3. leejor
    11,095
    327
    Transfer should work for you as long as you are under the four concurrent call limit in the free edition. There is a chart on the site listing the various features (restrictions) on each edition. I have never seen anything mentioning a "trial period".
    Faxing over VoIP is always "iffy". It comes down to having all the things set up just right, a certain type of fax machine, a certain VoIP provider that handles Fax properly, or an ATA set up to properly handle Fax. Go back through the Forums and you can see some of the problems encountered trying to get a fax machine working over VoIP. If you are lucky, and have everything set up just right, then it might work, but it may require a lot of trial and error before you end up realizing it won't, in your case.
  4. druid33
    Mar 26, 2010
    I try to transfer calls with Planet VoIP Phones. They are (i think )not supported by 3cx and that can be problem. If i use 3cx (software) Phones, there is no problem with transfering calls.
  5. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Yes they are not supported, You would have to play around a bit to get them to work, if they will at all. It is probably a re-invites, re-places problem. On the other hand you can transfer calls, just remember that a call being transferred you have to add 1 extra call to the call count. so that's 3 calls until there connected even for blind transfer.
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can configure all extensions which are handled by "Planet VoIP Phones" as "supports re-invites=off". It will remove misunderstanding between your phones and 3CX PBX and will make them supported on the 3CX PBX side :)
    If you have further question/information/reclamation then please follow guidelines specified in http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
  7. druid33
    Mar 26, 2010
    Hi, thanks for reply, they was useful, but....
    so i configure "supports re-invites=off". The Attendant transfer now work, but Blind transfer not!
    Than i try configure "supports re-invites=on" and "support ´replaces´ header=off", but nothing changed.
    i make transfering like it is describe in manual for planet phones.that is:
    Blind Transfering:
    1. B call to A and they are in process of conversation
    2. A press "FLASH" button to hold the conversation with B, and input the number of C (follow by the "#" key).
    3. C will ring up, and A hang up the handset.
    4. C picks up the handset and conversation with B.
    I try describe the situation. I have 3 Panet Phones with number and id 15, 16, 17. 15 make a call to 16, 16 make a Blind transfer(like is describe in manual for planet phones) to 17.
    and here is log:
    Code:
    10:11:07.828  Active calls counted toward license limit: []
    10:10:39.421  [MS105000] C:15.1: No RTP packets were received:remoteAddr=0.0.0.0:60000,extAddr=0.0.0.0:0,localAddr=10.0.1.10:7056
    10:10:38.078  [CM503008]: Call(15): Call is terminated
    10:10:35.828  Active calls counted toward license limit: [15]
    10:10:32.765  [CM503008]: Call(16): Call is terminated
    10:10:10.609  [CM503007]: Call(16): Device joined: sip:17@10.0.1.217:5060
    10:10:10.609  [CM503007]: Call(16): Device joined: sip:16@10.0.1.216:5060
    10:10:07.156  [CM503016]: Call(15): Attempt to reach <sip:17@10.0.1.10> failed. Reason: Busy
    10:10:07.156  [CM503014]: Call(15): No known route to target: <sip:17@10.0.1.10>
    10:10:07.156  [CM503010]: Making route(s) to <sip:17@10.0.1.10>
    10:10:05.984  [CM505001]: Ext.17: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE  (803060)] PBX contact: [sip:17@10.0.1.10:5060]
    10:10:05.984  [CM503002]: Call(16): Alerting sip:17@10.0.1.217:5060
    10:10:05.687  [CM503025]: Call(16): Calling Ext:Ext.17@[Dev:sip:17@10.0.1.217:5060]
    10:10:05.625  [CM503004]: Call(16): Route 1: Ext:Ext.17@[Dev:sip:17@10.0.1.217:5060]
    10:10:05.625  [CM503010]: Making route(s) to <sip:17@10.0.1.10>
    10:10:05.625  [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE  (803060)] PBX contact: [sip:16@10.0.1.10:5060]
    10:10:05.625  [CM503001]: Call(16): Incoming call from Ext.16 to <sip:17@10.0.1.10>
    10:10:03.828  Active calls counted toward license limit: [15]
    10:10:01.875  [MS004001] C:15.2: Can't send RTP stream to 0.0.0.0:60000 destination unreachable
    10:10:00.671  [CM503007]: Call(15): Device joined: sip:16@10.0.1.216:5060
    10:10:00.671  [CM503007]: Call(15): Device joined: sip:15@10.0.1.215:5060
    10:09:56.890  [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K-PHONE  (803060)] PBX contact: [sip:16@10.0.1.10:5060]
    10:09:56.890  [CM503002]: Call(15): Alerting sip:16@10.0.1.216:5060
    10:09:56.593  [CM503025]: Call(15): Calling Ext:Ext.16@[Dev:sip:16@10.0.1.216:5060]
    10:09:56.546  [CM503004]: Call(15): Route 1: Ext:Ext.16@[Dev:sip:16@10.0.1.216:5060]
    10:09:56.546  [CM503010]: Making route(s) to <sip:16@10.0.1.10>
    10:09:56.546  [CM505001]: Ext.15: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VIP-154T] PBX contact: [sip:15@10.0.1.10:5060]
    10:09:56.531  [CM503001]: Call(15): Incoming call from Ext.15 to <sip:16@10.0.1.10>
    Is here someone who understand, what is doing inside 3cx and know whats false?
    thanks for reply
