Transfer call back to transferer.
Discussion in 'Ideas' started by net-products, Dec 11, 2017.
Transfer call back to transferer. 5 5 4votes
5/5, 4 votes
  1. net-products
    Nov 28, 2017
    12
    We run into a problem with transferd call which i do not have a solution for.
    Calls get transferd but when the Extension has 20 seconds defined for 'If I do not answer calls within: xx seconds. Forward internal calls to:', it will go to the set setting. Lets say we have End Call set here.
    The call will be ended when the 20 seconds are passed while its a transferd call, why would it not be transfered back to the transferer so they can either tell the caller the person isn't there or transfer to someone else?
    The idea:
    - Transfer the call back to the transferer as option in the Internal Calls.
  2. net-products
    Nov 28, 2017
    12
