Transfer call from windows to IP phone
Discussion in 'Windows' started by nikivk, Aug 21, 2016.
  1. nikivk
    Aug 21, 2016
    I just installed a 3CX-system in a small business (35 users).
    Most of the users using a dect-phone (Snom).
    I've provided the receptionists with a headset as well, to use the windows application and that works great!
    They mostly use the windows application, because it's easier to use a pc with both hands free...
    the PC and dect-phone are using the same extension.
    Is there a way to transfer the call from the windows-application to their own dect-phone?
    I haven't found a solution on this forum and in the manuals.
    Kind regards,
    Niki
    10,375
    231
    I assume that you are having a problem because they're both the same extension number number.
    You could try setting that extension to allow more than one call at a time. If you can call from one to the other, without the number "status" being busy, then transfer might work. I haven't tested that scenario myself, but it's worth a try.
  3. neville
    neville New Member
    Apr 23, 2012
    202
    33
    This works as leejor states. You can transfer between IP phones, windows clients, and mobile clients. I just tested.
    Chuck
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    fwiw, I park/unpark.. seems to be less messy (like.. routing off to my own voicemail if I fail to pick it up, etc..).
