Transfer Call Priority
Discussion in '3CX Phone System - General' started by lpis, Aug 13, 2015.
  1. lpis
    Aug 13, 2015
    I am having a problem that I cannot work out how to get around at the moment
    All our phones are members of various queues as part of our call centre. The problem I have through that this prevents call transfers working effectively
    If you want to transfer a call to another extension this is only possible when there is no call in the queue, otherwise the recipient has no choice but to take the queued call. Is there anyway that a direct call or transfer to an extension can override the queue and be first priority?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    You can enable the option to allow more than one call simultaneously on the extension so that the second line will blink if you try to transfer a call, then the user choose between queue call or line 2 direct call.
    Note this option is not compatible with CTI.
