Transfer call, received on GXW4104
Discussion in '3CX Phone System - General' started by logsim, Sep 23, 2014.
  1. logsim
    Sep 23, 2014
    Using a GXW4104 and a BT line, 3CX system (37098.738), a Grandstream DP715 and a 3CX windows phone (12.0.36097)
    Pick up the call on the DP715 - OK - have conversation
    Transfer to the windows phone - connects and have attended conversation whilst music plays on the incoming call
    Hang up the DP715 - windows phone says "put on hold" and all buttons greyed out
    Incoming call - nothing but still connected
    How can the windows phone pickup the call?
    If the call is from a SIP line then it works perfectly
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try altering 'Support Re-invite' and 'Support Replaces' into Advanced setting for your gateway.
  3. logsim
    Sep 23, 2014
    Thank you Eagle2
    Under profile1 I changed "Force INVITE" from no to yes
    It now works
