Transfer calls directly to voicemail
Discussion in '3CX Phone System - General' started by garyjduk, Aug 20, 2010.
  1. garyjduk
    Aug 11, 2009
    70
    Does anyone know how to transfer a call directly to another extension's voicemail without that extension ringing?
    We are using Snom 320/360's and can find very little information on doing it.
    I found a forum question relating to Version 5 and it said Blind Transfer with *4 before the extension but we can't seem to get this to work.
    Also is there anywhere on the 3CX site with a full list of dial codes - so I can print it out and give it to a customer as an reference?
  2. danoh
    Aug 18, 2010
    56
    I think it's *4xxx where xxx is the extension. You would need to blind transfer the call.
    What I'm trying to figure out is a way I can setup a softkey on a Cisco phone to do this automatically.
    During a call, I want to be able to press a softkey called, say, xferVM and then enter the extension number and be done with it.
    Having to tell my customers in order to transfer a call to someone's voicemail they have to press bxfer, dial *4112 and press dial is not very user friendly.
    Hoping to get some help.
  3. danoh
    Aug 18, 2010
    56
    Still looking for a way to solve this issue...
