Transfer Calls Failing to reach voicemial.
Discussion in '3CX Phone System - General' started by iamgreen, Mar 12, 2008.
  1. iamgreen
    Sep 25, 2007
    52
    I noticed that if I pick up a call on the inbound trunk, then transfer it to an internal extention it will ring the normal amount of times, then the caller is placed on perpetual hold. Anyone seen this before?
