Transfer calls interactively from one extension to another?
Discussion in '3CX Phone System - General' started by marcomb, Jul 30, 2007.
  1. marcomb
    Jul 30, 2007
    8
    Hallo
    Which is the key sequence to put ON HOLD and TRANSFER a call to another internal extension? I am expecting to have something like "*67*Extension" to transfer the call to another one
    I also need to know which sequence is required to take the call ownersip
    I just have the followings manuals
    3CXPhoneSystemManual31.pdf
    3CXCallAssistantmanual31.pdf
    Is there anything else available?
    Marco Combetto
    Nibble Computer Solutions
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    What phones are you using?
    Most hardware and software phones have a hold button.
    Most hardware phones have a xfer button, most softphones have a xfer button with some exceptions:
    3cx Softphone - no xfer button
    3cx CallAssistant - you can xfer a call.
    X-Lite - upgrade is needed to get the xfer button enabled.
  3. m5QG4
    Jul 30, 2007
    10
    3cx CallAssistant - transfer and etc ..... not for free version. It only enable SBE, PRO and ENT.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Sorry I thought that was part of the free version of CA. I knew it had some limits but wasn't sure what that was. I'm using a purchased version so I forget what's added with the license.
  5. m5QG4
    Jul 30, 2007
    10
    Hi marcomb,
    The current version of 3CX PBX not */# + code function to support those SIP call for transfer, 3-way conference and etc ..... Except the SIP phone build-in these function.
  6. marcomb
    Jul 30, 2007
    8
    Thanks for the prompt help! I see... not so easy..
    Is it the same for the Voice Mail? For example with another PBX server, you have the following command to interact with your voice mail?
    06*<extension> --- IVR
    07*<extension> --- Voicemail greeting
    08*<extension> --- Voicemail review/Setting
    8 --- Access your own Voicemail box by dialing 8 from phone
    Do you have hints to provide a more interaction with the Voice mail
    Thanks again
    Marcomb
  7. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    To reach voicemail from any extension just dial 999. Then you will get the regular enter extension, enter password prompts. Doesn't matter what phone you use. From there you have all the options - change greetings, password, etc.
  8. marcomb
    Jul 30, 2007
    8
    Yep! Works pretty well. ThxU
