Transfer calls to another voicemail
Discussion in 'Windows' started by markslowe, Nov 15, 2013.
  1. markslowe
    Jan 4, 2013
    5
    This feature was available in MyPhone but now is missing from the presence screen/3cx phone. Please bring it back ASAP!
  2. williamsonchong
    Sep 29, 2013
    5
    We love that drag to drop made it back to 3cxPhone. Now we are waiting on one of the main features for us to return as well. Please give us back the ability to transfer a call to voicemail.
  3. norekhov
    3CX Support
    Jan 31, 2014
    53
    At least this feature is already there.
    You could divert or transfer any call to any voicemail through Presence Window.
    Just select the voicemail in selection dialog.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    But it is not drag drop
    You have to right click and select divert
    Then enter their extension and selection phone or to voicemail.
    This could take too much time. A drag and drop would be great then when you hovered over the extension it gave you the options...
  5. norekhov
    3CX Support
    Jan 31, 2014
    53
    Well, this is another disadvantage.
    Now when you drag-and-drop a call to an extension it transfers without options.
    If I'll do it with options than someone might say "I don't want this options, I don't want this voicemail variant, just transfer!!"
    So it's better to post it as an idea and see if it is required.
