transfer calls without call assistant?
Discussion in '3CX Phone System - General' started by 5qg4, Nov 9, 2007.
  1. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Ahsan,
    This feature should be supported by the phone not the PBX. Normally, most of hardware phone already build-in transfer key. If you are using ATA adapter, most of them are already predefined transfer feature as well. Please let us know which hard phone in-use.
    For Grandstream HT488:
    Blind Transfer
    This function is applicable on FXS port for VoIP calls only. Assume that call party A and B are in
    conversation. A wants to Blind Transfer B to C:
    1. A press FLASH on the analog phone to hear the dial tone.
    2. Then A dials *87 then dials C’s number, and then #
    3. A can hang up.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Read this.
    http://www.3cx.com/forums/categories-1/version-4-beta-feedback-6/call-park-2781/
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Sounds like you need new phones. Even cheap phones can do this.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    OK By cheap phones I meant $60. I didn't know they made them cheaper than that!
    Currently there is no provision to transfer calls from the keypad. Version 4 will have call parking which may help you out.
