transfer dial code
Discussion in 'Windows' started by muaddib32, Apr 5, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    Is there a dial code for transferring calls? I can't see it mentioned in the user manual. I have a user using a cordless handset connected to an ATA. She would like to be able transfer calls.
    11,123
    330
    Some ATA's do have star codes (*xx) to perform tasks such as blind transfer, however, as far as I know they all require a flash first. Most modern cordless phones do include a flash (also called "recall") key. An attended transfer is normally, flash, get dialtone, dial number, announce call, hang up.
  3. Gabrielwer
    Sep 9, 2011
    hello!! Coulou tell me is it possibleto use a cordless phone with my MagicJack??
  4. willow
    willow Member
    Mar 1, 2011
    471
    get a cordless headset for the magicjack.
