Transfer extension to direct SIP calls?
Discussion in '3CX Phone System - General' started by zyonee, Jul 7, 2008.
  1. zyonee
    Dec 5, 2007
    12
    Hi!
    I don't know if this has been asked already, but would it be possible to forward an extension to for example user@sipserver.com instead of a regular telephone number?
  2. Anonymous
    Anonymous Guest
    Hi there,
    At best, this would be a feature request.
    However, as Matt said, are you also intending this for hard phones?
    Thanks,
  3. zyonee
    Dec 5, 2007
    12
    No, actually I was asking about a forward, so for example, if line 1001 doesn't pick up an incoming call, the call will automatically be forwarded to, for example, user@sipserver.com. This you can already type in today in the forwarding configuration of voip lines. However, I don't think the server understands what to do with this information, it can only process real phone numbers.
  4. Anonymous
    Anonymous Guest
    Please add this as a feature request.
    Thanks,
