Transfer fails
Discussion in 'Windows' started by bahosi, Feb 1, 2012.
  1. bahosi
    Feb 1, 2012
    I like the 3cx-Phone very much, but i have a little problem and I hope you can help me! (and i hope you understand my bad english. :D )
    Following configuration: 3cx logs in into my FritzBox 7390. And my FritzBox has the Data of the Voip/SIP-Account saved. The Calls are working very well with the software.
    The problem: Everytime i try to transfer the call it says "server error".
    It would be really nice if someone is able tohelp me. :) If you need any more data, I will post them here!
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Replace your fritzbox with 3cx phonesystem.
    With sure this helps ...
  3. leejor
    10,368
    229
    You may need to use Wireshark and capture exactly what messages are being sent during a transfer, obviously something that your Fritzbox doesn't like. You may not be able to ultimately do anything about it.
    You might have to contact the people that make Fritzbox, with the Wireshark information to ask why it doesn't work.
