Transfer from Android to IP Phone
Discussion in 'Android' started by Kevin Burns, May 1, 2017.
  1. Kevin Burns
    Apr 3, 2017
    43
    Hello, I have been trying to figure this out but can't. what I am trying to do is transfer a call from my android phone to my desk phone that are both provisioned under the same extension. It would be more of moving a call than actually transferring it.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Hello @Kevin Burns
    Please note that you can do this with either enabling accept multiple calls under extension settings / Forwarding rules and just blind transfer the call to your extension or with parking the call and picking it up from the deskphone.
