Transfer if no answer to external line (cell phone)
Discussion in '3CX Phone System - General' started by redwood, Apr 14, 2008.
  1. redwood
    Jan 29, 2008
    20
    I've searched the forum and tried almost everything i can think off, but i can't transfer to an outside line.
    I've made an extra extension ie. 123. and select forward all calls to oudside number.
    i've filled in my cell phone number in the outside number block. ie. 0612345678 . This is a dutch cellphone number without any extra prefixes. And i think that's where the problem is.
    Do i need to put an string or prefix in front of that number??
  2. paragondie
    Jun 25, 2007
    52
    You need to dial the number proceeded by the prefix you have setup in your outbound rule.
  3. Arnaud
    Nov 23, 2007
    43
    Can you call your mobile from a phone connected to your 3CX server ? Which number do you dial ?
    The number in your outbound rule should be the same as the number you key in on your phone when dialing your mobile phone. Certain VOIP providers expect you for example to include the country code. In that case it would be 0031612345678, potentially even with a prefix for a 3CX external line. The last depends on how you did setup your server.
  4. phxlad
    Mar 24, 2008
    13
    Did you get it corrected?
    My call forward works when an extension calls an extension but not from an outside line.
  5. Halea
    Halea New Member
    Jan 5, 2008
    151
    Redwood,
    Also remember that the extension that you are trying to forward to an outside number needs to be registered. In other words, if the VOIP handset, or soft phone has not registered its presence into 3CX, the no answer or busy transfer won't work. So, check to make sure that your extension indicator is turned green on the 3CX status webpage.
    Good luck.
    Halea
  6. Ricambi America
    Nov 10, 2007
    61
    Yes, it does work... but the setup is incredibly obtuse. See the last post in this thread:
    http://www.3cx.com/forums/4393-impressions-4886.html#p22842
