transfer problem
Discussion in '3CX Phone System - General' started by 3cx_ user, Jan 28, 2008.
  1. 3cx_ user
    Jan 28, 2008
    i can't transfer incoming call, please type the decision of problem
    15:23:54.984 StratLink::eek:nHangUp [CM104001] Call(116): Ext.102 hung up call; cause: unknown
    15:23:17.125 MediaServerReporting::RTPSender [MS004000] Call(116) Ext.102: (ACTIVE): Can't send RTP stream to 0.0.0.0:7502 destination unreachable
    15:23:01.421 CallLegImpl::eek:nConnected [CM103001] Call(116): Created audio channel for Ext.102 (192.168.1.102:7502) with Media Server (192.168.1.10:7356)
    15:23:01.421 StratInOut::eek:nConnected [CM104005] Call(116): Setup completed for call from Ln:10004@3004S_4 to Ext.102
    15:22:59.093 CallConf::eek:nProvisional [CM103003] Call(116): Ext.102 is ringing
  2. LLangston
    Aug 27, 2007
    57
    Are you using a 'Blind Transfer' or an 'Attended Transfer' method? Does it disconnect the call about 30sec after the transfer or during the transfer? What equipment are you using i.e what gateway? what phones?
