transfer the Caller ID
Discussion in '3CX Phone System - General' started by dnwklin, Feb 2, 2009.
  1. dnwklin
    Feb 2, 2009
    10
    Hi everyone,
    I just want to know that if I transfer a call to an external number, does the 3CX support to bring the Caller ID to the external number via Voip provider? Thanks
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    When you divert a call to an outside number , the caller ID you will have displayed on the receiving phone will be the one of the line that is used to dial out to divert the call.
    regards
  3. NRG
    NRG
    Dec 24, 2008
    31
    Alex,
    Is there any way around this? I would like to see the number of the person calling me, not the office's number.
  4. leejor
    11,105
    329
    I think that the only way a forwarded call will show the originators number is... if you are using the call forward feature that your phone company offers, your phone is on a Centrex switch, or you have a PBX using a PRI that is capable of relaying the caller ID on the outbound leg.
