Transfer to external numbers
corradini2
I try to download a link to an external number without success.
Could someone tell me why not work?
Or only works in the paid versions?
An example:
I have 4 lines installed in 3CX and 4 Branches properly configured and running.
The phone "11 1111 1111" is set to transfer all calls to the extension "A".
The extension "A" is configured to transfer all calls to an external number "00 0000 0000.
If you connect to the number "11 1111 1111", the transfer does not occur, we hear the busy signal.
The most interesting is that if I connect the branch "B" for the extension "A" the transfer occurs normally.
Please, anyone who can help I will be in waiting. Thanks
Use a Grandstream HT286.
log server
12:02:02.765 [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]:5060/11]
12:01:55.375 [CM504002]: Ext.11: a contact is unregistered. Contact(s): []
12:01:54.296 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
12:01:09.015 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
12:00:49.375 [CM503008]: Call(74): Call is terminated
12:00:49.359 [CM503019]: Normal call termination. Reason: Outbound rule is not found
12:00:49.359 [CM303006]: There's no outbound rule for external number '032870448' defined
12:00:49.343 [CM303006]: There's no outbound rule for external number '032870448' defined
12:00:49.312 [CM503010]: Making route(s) to <sip:[email protected]:5060>
12:00:49.312 [CM505003]: Provider:[19 3515 7447] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Huawei SoftX3000 V300R006B06D060SP32] Transport: [sip:189.112.176.10:5060]
12:00:49.281 [CM503001]: Call(74): Incoming call from 11997942908@(Ln.10047@19 3515 7447) to <sip:[email protected]:5060>
12:00:49.281 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10047 forwards to DN:10
12:00:22.890 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:59:37.671 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:58:52.500 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:58:07.234 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:57:39.484 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:57:23.406 [CM503008]: Call(73): Call is terminated
11:57:23.406 [CM503019]: Normal call termination. Reason: Outbound rule is not found
11:57:23.406 [CM303006]: There's no outbound rule for external number '032870448' defined
11:57:23.375 [CM303006]: There's no outbound rule for external number '032870448' defined
11:57:23.343 [CM503010]: Making route(s) to <sip:[email protected]:5060>
11:57:23.343 [CM505003]: Provider:[19 3515 7447] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Huawei SoftX3000 V300R006B06D060SP32] Transport: [sip:189.112.176.10:5060]
11:57:23.312 [CM503001]: Call(73): Incoming call from 11997942908@(Ln.10047@19 3515 7447) to <sip:[email protected]:5060>
11:57:23.312 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10047 forwards to DN:10
11:57:21.406 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:56:35.031 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:56:10.093 [CM503008]: Call(72): Call is terminated
11:56:10.078 [CM503019]: Normal call termination. Reason: Outbound rule is not found
11:56:10.078 [CM303006]: There's no outbound rule for external number '032870448' defined
11:56:10.062 [CM303006]: There's no outbound rule for external number '032870448' defined
11:56:10.031 [CM503010]: Making route(s) to <sip:[email protected]:5060>
11:56:10.031 [CM505003]: Provider:[19 3515 7447] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Huawei SoftX3000 V300R006B06D060SP32] Transport: [sip:189.112.176.10:5060]
11:56:10.000 [CM503001]: Call(72): Incoming call from 11997942908@(Ln.10047@19 3515 7447) to <sip:[email protected]:5060>
11:56:10.000 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10047 forwards to DN:10
11:55:51.421 [CM504004]: Registration succeeded for: 10047@19 3515 7447
11:55:51.093 [CM504003]: Sent registration request for 10047@19 3515 7447
11:55:49.812 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:55:47.421 [CM504003]: Sent registration request for 10047@19 3515 7447
11:55:25.312 [CM504001]: Ext.12: new contact is registered. Contact(s): [sip:[email protected]/12]
11:55:04.593 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:54:19.359 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:53:34.140 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:52:48.921 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:52:39.265 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:52:03.437 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:51:17.578 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:50:32.031 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:49:46.812 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:49:01.437 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:48:15.781 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:47:39.046 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:47:29.640 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:46:44.312 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:45:59.078 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:45:13.812 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:44:28.593 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:43:42.203 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:42:56.968 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:42:38.828 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:42:10.187 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:41:53.921 [CM504002]: Ext.10: a contact is unregistered. Contact(s): []
11:40:47.359 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:39:59.078 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:39:58.531 [CM504002]: Ext.10: a contact is unregistered. Contact(s): []
11:39:34.312 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:39:33.171 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:39:32.671 [CM504002]: Ext.10: a contact is unregistered. Contact(s): [sip:[email protected];user=phone/10]
11:39:10.062 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:39:08.890 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:38:23.640 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:37:38.609 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:37:38.468 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:36:53.093 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:36:07.859 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:35:22.625 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:34:37.390 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:33:52.109 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:33:06.796 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:32:38.390 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:32:21.562 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:31:48.515 [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]:5060/11]
11:31:36.343 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:30:51.109 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:30:05.828 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:29:20.609 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:28:34.390 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:27:49.171 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:27:38.171 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:27:03.953 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:26:18.734 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:25:45.750 [CM504001]: Ext.12: new contact is registered. Contact(s): [sip:[email protected]/12]
11:25:33.468 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:24:48.250 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:24:02.984 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:23:17.765 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:22:37.953 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:22:32.546 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:21:47.328 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:21:02.109 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:20:16.843 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:19:30.687 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:18:45.468 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:18:00.234 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:17:37.734 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
11:17:14.937 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:16:29.718 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:15:44.500 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:14:59.265 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:14:13.734 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:13:28.328 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:[email protected];user=phone/10]
11:12:38.515 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
hello,
first make an outbound line look server said -> 12:00:49.343 [CM303006]: There's no outbound rule for external number '032870448' defined
do to outbound rules and make new. like this number "start with 0" use "route x"...
check again and said me.
Getting Started - Admin
Ramishvohrw
Get 3CX - Absolutely Free!
3CX
