Transfer to Greeting
Discussion in '3CX Phone System - General' started by brianoakes, Oct 10, 2012.
  1. brianoakes
    May 12, 2012
    95
    Is there a way to have a transfer to greeting? What I mean is when you dial an extension from a menu it will says you are now being tranferred to the persons name.
    Make sense? Possible?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    well it can be done (i think), check this topic:
    https://www.3cx.com/forums/call-recording-notification-6277.html
    Based on the extension you dialed you can change default prompt "Please hold while I transfer your call." with your custom prompt. you will have to create custom prompt for each extension (for Tom, Bob....) so when you dialed Bob`s extension you get message " you are now being tranferred to Bob"...
