Transfer to VM
Discussion in 'Windows' started by craigreilly, Jul 9, 2015.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Anyway to transfer a call to a users mobile?
    I see Transfer and <enter number> or Drag and Drop to Transfer to user extension.
    What if a VP runs out to lunch and says "only if Jack calls send it to my cell phone". I can't go tell them to setup an exception.
    The receptionist should be able to Transfer to Mobil. Maybe it is there and I am missing it.
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi there,
    This can be done automatically you can set up exceptions for the VP in their extensions settings > forwarding rules > exceptions tab. Also set up forwarding rules to ring the mobile when they are activated. Set up office hours so that calls only get routed during the hours you need.
    Then when they have set a status to away or out of office ect... the call will be routed to the mobile. Obviously you will have to tell them to set their status when they step out.
  3. positron
    Jan 14, 2013
    74
    9
    Assuming their mobile number is programmed for their extension, you can click Transfer (or Att. Transfer) on the active call, then click on the Presence section, find their extension, and click the Call Mobile option.
  4. craigreilly
    Feb 1, 2012
    2,978
    183
    Charles_3cx - you missed the point completely.
    Positron - I will give it a shot.
    Thank you.
