Transfer to Voice Mail via Softphone / Software
Discussion in '3CX Phone System - General' started by wired1, Oct 7, 2016.
  1. wired1
    Oct 5, 2010
    17
    I know that you can transfer to voice mail via the *4 code however it is kind of a pain to have to look up an extension number first then remove from the lookup to type the *45215 to send to voicemail of a user. It would be nice that when you did a lookup for a transfer via the softphone that you would not only see the persons cell number and or other numbers but a transfer to voicemail option that you could then click on and it would know to dial the call code to send to that users VM Box.
    Matthew Evans
    Wired Sphere Technologies
  2. Patrick Hogan10
    Nov 23, 2016
    27
    I agree with you Wired1. I hope we'll be able to that soon.
