Transfering calls?
Discussion in '3CX Phone System - General' started by C51, Aug 30, 2007.
  1. C51
    C51
    Aug 10, 2007
    18
    hello people
    have now go the 3cx system working like it should apart from a few errors but i dnt mind
    right how do you transfer calls using this system then?
    thanks
    Jordan
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    On my Eyebeam softphone using button, also using 3CX Call Assistant (don't like having to use another piece of software though), and blind via my ATA menu ( *98 ). Softphone solution best but I use more analog than softphone so a bit of a pain. 3CX has call pickup only implemented via key entry (*10* or 9100 default I think, I changed it) at this time, more options to come in the future release(s).
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    What type of transfer (attended or blind)?
    Here just the example of Polycom phone
    Attended transfer:
    PSTN ->EXT 100->Transfer to EXT 200
    Press transfer key> Key in EXT 200> wait for EXT 200 pick the phone, then told EXT 200 user "Peter on the line" > press transfer key again
    *** PSTN caller ID will be override by EXT 100's outbound ID ***
    Blind transfer:
    Press transfer key> press Blind key > Key in EXT 200> press transfer key again > off hook
    *** PSTN caller ID will show at EXT 200's display ***
