- Joined
- Jan 29, 2013
- Messages
- 27
- Reaction score
- 0
Hi all,
trying to figure out problems with call transfers.
When i transfer the call, it still shows as "transferring" even though both parties can already talk. Can only end it by clicking "end call". Both parties are still able to talk each other though..
Also i get strange/interesting messages in the logs:
Let's say (numbers are changed) 9999999999 called 1111111111. Then 103 picked up the call and transferred to 105.
222.222.222.222 is our public ip,
74.112.200.122 - cloud pbx's ip,
67.102.144.50 - sip trunks ip
22-Apr-2015 12:13:41.209 Leg L:2164.1[Line:10001<<9999999999] is terminated: Cause: BYE from PBX
22-Apr-2015 12:13:41.209 [CM503008]: Call(C:2164): Call is terminated
22-Apr-2015 12:13:41.208 Leg L:2164.3[Extn] is terminated: Cause: BYE from 222.222.222.222:12163
22-Apr-2015 12:13:41.005 Leg L:2164.4[Extn] is terminated: Cause: BYE from 222.222.222.222:12165
22-Apr-2015 12:13:21.915 Currently active calls - 1: [2164]
22-Apr-2015 12:13:20.930 [MS105000] C:2309.1: No RTP packets were received:remoteAddr=74.112.200.122:15730,extAddr=0.0.0.0:0,localAddr=74.112.200.122:58628
22-Apr-2015 12:12:59.475 [MS104000] C:2164.1: (ACTIVE) RTP stream to 67.102.144.50:51412 restored.
22-Apr-2015 12:12:59.240 Leg L:2165.1[Extn] is terminated: Cause: BYE from PBX
22-Apr-2015 12:12:59.210 [CM503008]: Call(C:2165): Call is terminated
22-Apr-2015 12:12:58.021 [CM503007]: Call(C:2165): Extn:105 has joined, contact <sip:[email protected]:12165>
22-Apr-2015 12:12:58.020 [CM503007]: Call(C:2165): Extn:103 has joined, contact <sip:[email protected]:12163>
22-Apr-2015 12:12:58.019 L:2165.2[Extn] has joined to L:2165.1[Extn]
22-Apr-2015 12:12:56.289 [CM503025]: Call(C:2165): Calling T:Extn:105@[Dev:sip:[email protected]:12165] for L:2165.1[Extn]
22-Apr-2015 12:12:56.240 [CM503027]: Call(C:2165): From: Extn:103 ("Marry" <sip:[email protected]:5060>) to T:Extn:105@[Dev:sip:[email protected]:12165]
22-Apr-2015 12:12:56.240 [CM503004]: Call(C:2165): Route 1: from L:2165.1[Extn] to T:Extn:105@[Dev:sip:[email protected]:12165]
22-Apr-2015 12:12:56.239 [CM503001]: Call(C:2165): Incoming call from Extn:103 to <sip:[email protected]:5060>
22-Apr-2015 12:12:55.354 [MS004000] C:2164.1: (ACTIVE): Can't send RTP stream to 0.0.0.0:51412 destination unreachable
22-Apr-2015 12:12:53.154 [MS104000] C:2164.1: (ACTIVE) RTP stream to 67.102.144.50:51412 restored.
22-Apr-2015 12:12:53.126 Leg L:2164.2[Ivr] is terminated: Cause: BYE from 127.0.0.1:5483
22-Apr-2015 12:12:52.922 [CM503007]: Call(C:2164): Extn:103 has joined, contact <sip:[email protected]:12163>
22-Apr-2015 12:12:52.920 L:2164.3[Extn] has joined to L:2164.1[Line:10001<<9999999999]
22-Apr-2015 12:12:50.605 [CM503025]: Call(C:2164): Calling T:Extn:103@[Dev:sip:[email protected]:12163] for L:2164.1[Line:10001<<9179031912]
22-Apr-2015 12:12:50.598 [CM503027]: Call(C:2164): From: Line:10001<<9999999999 ("Bob" <sip:[email protected]:5060>) to T:Extn:103@[Dev:sip:[email protected]:12163]
22-Apr-2015 12:12:50.598 [CM503004]: Call(C:2164): Route 1: from L:2164.1[Line:10001<<9999999999] to T:Extn:103@[Dev:sip:[email protected]:12163]
22-Apr-2015 12:12:50.454 [MS004000] C:2164.1: (ACTIVE): Can't send RTP stream to 0.0.0.0:51412 destination unreachable
22-Apr-2015 12:12:49.913 Currently active calls - 1: [2164]
22-Apr-2015 12:12:41.482 [CM503007]: Call(C:2164): Ivr:900 has joined, contact <sip:[email protected]:5483>
22-Apr-2015 12:12:41.481 [CM503007]: Call(C:2164): Line:10001<<9999999999 has joined, contact <sip:[email protected]:5060>
22-Apr-2015 12:12:41.480 L:2164.2[Ivr] has joined to L:2164.1[Line:10001<<9999999999]
22-Apr-2015 12:12:41.330 [CM503025]: Call(C:2164): Calling T:Ivr:900@[Dev:sip:[email protected]:5483;rinstance=db3c5ef0da557aa3] for L:2164.1[Line:10001<<9999999999]
22-Apr-2015 12:12:41.284 [CM503027]: Call(C:2164): From: Line:10001<<9999999999 ("Bob" <sip:[email protected]:5060>) to T:Ivr:900@[Dev:sip:[email protected]:5483;rinstance=db3c5ef0da557aa3]
22-Apr-2015 12:12:41.284 [CM503004]: Call(C:2164): Route 1: from L:2164.1[Line:10001<<9999999999] to T:Ivr:900@[Dev:sip:[email protected]:5483;rinstance=db3c5ef0da557aa3]
22-Apr-2015 12:12:41.284 [CM505003]: Provider:[megapath] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:[email protected]:5060]
22-Apr-2015 12:12:41.283 [CM503001]: Call(C:2164): Incoming call from Line:10001<<9999999999 to <sip:[email protected]:5060>
Phones are provisioned using STUN, TCP and UDP ports are port-forwarded and allowed on the firewall.
Also when i click "phones" in the web gui, it shows private ip's for "IP of Phone", not the public ones. Is that the expected behavior?
Tried my luck with "supports re-invite" and "supports replace" - no luck. Do i need to restart some 3cx services after i do such changes to my SIP provider's config?
Not using SBCs or proxies in any of our offices (want to remove as many single points of failure as possible).
Thanks for any thoughts!
