transfers fail
Discussion in '3CX Phone System - General' started by nateb, Nov 26, 2007.
  1. nateb
    Oct 19, 2007
    68
    For some reason, my transfers keep failing. Here is the log file :
    [CM104001] Call(35): Ext.102 hung up call; cause: BYE; from IP:172.16.1.42
    08:53:40.852 StratTransfer::finishTransfer [CM108005] Call(35): Transfer finished, Ext.102 is connected to Ln:10101@tek-hut line 1 and 2
    08:53:40.852 StratTransfer::eek:nConnected [CM008008] Call(35): Transfer: wrong leg is connected
    08:53:40.852 StratTransfer::returnToLink [CM108004] Call(35): Transfer failed, restore call between Ext.102 and Ln:10101@tek-hut line 1 and 2
    08:53:38.274 StratLink::Transfer [CM104002] Call(35): transfers Ln:10101@tek-hut line 1 and 2 from Ext.102 to sip:9101@172.16.1.4
    08:53:26.587 CallLegImpl::eek:nConnected [CM103001] Call(35): Created audio channel for Ext.102 (172.16.1.42:5004) with Media Server (172.16.1.4:7406)
    08:53:26.571 StratInOut::eek:nConnected [CM104005] Call(35): Setup completed for call from Ln:10101@tek-hut line 1 and 2 to Ext.102
    08:53:26.540 CallLegImpl::eek:nConnected [CM103001] Call(35): Created audio channel for Ln:10101@tek-hut line 1 and 2 (172.16.1.56:6000) with Media Server (172.16.1.4:7400)
    08:53:21.900 CallConf::eek:nProvisional [CM103003] Call(35): Ext.103 is ringing
    08:53:21.540 CallConf::eek:nIncoming [CM103002] Call(35): Incoming call from 2088342269 (Ln:10101@tek-hut line 1 and 2) to sip:10101@172.16.1.4
    08:52:25.808 StratLink::eek:nHangUp [CM104001] Call(34): Ext.102 hung up call; cause: BYE; from IP:172.16.1.42
    08:52:25.121 StratTransfer::finishTransfer [CM108005] Call(34): Transfer finished, Ext.102 is connected to Ln:10101@tek-hut line 1 and 2
    08:52:25.121 StratTransfer::eek:nConnected [CM008008] Call(34): Transfer: wrong leg is connected
    08:52:25.121 StratTransfer::returnToLink [CM108004] Call(34): Transfer failed, restore call between Ext.102 and Ln:10101@tek-hut line 1 and 2
    08:52:22.418 StratLink::Transfer [CM104002] Call(34): transfers Ln:10101@tek-hut line 1 and 2 from Ext.102 to sip:9101@172.16.1.4
    any ideas?
  2. nateb
    Oct 19, 2007
    68
    another part of transfer failed
    MS004000] Call(38) Ext.102: (ACTIVE): Can't send RTP stream to 0.0.0.0:5004 destination unreachable
  3. cinghiuz
    Nov 26, 2007
    Hi!
    I registered to this forum since i have the same problem.
    In my case i have got a PAP2T, i answer to an incoming call with an analogic phone connected to the PAP2T and then i transfer the call to an X-Lite extension.
    Everything works fine, but after exactly 55 seconds of conversation between the incoming caller and the person at X-Lite extension the line hangup.
    If i don't transfer the call i can talk for hours without problem.
    Any ideas?
    Thank you very much in advance to people will help me/us :)
    Cinghiuz
  4. nateb
    Oct 19, 2007
    68
    FIXED
    the problem was because I setup a dial plan on my phones, so it was adding a 9 when it was trying to transfer the call. Whoops!
  5. gstreetmedia
    Nov 15, 2007
    We get this too. Using Polycom IP 330 phones. These phone provide two methods of transfer, consultative and blind. Consultative, you call the extension you want to transfer to and ask if the user wants the call transferred, blind it just transfers. With consultative it always hangs up after 55 seconds. I have no idea how to fix it.
    --Andrew
  6. bigsiqc
    Nov 21, 2007
    23
    I have this problem too. It seems to be quite common.
    If I transfer between two aastra phones or two eyebeam softphones the transfer works well. It also works from softphones to the aastra phones. However, when you transfer between the aastra and a soft phone it disconnects in 35 seconds.
    I am guessing this is a software or setup issue for the aastra. Anyone got any ideas?
    Thanks in adviance
    Simon
  7. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good evening
    We are using Polycom Soundpoint IP 501s. I haven't had this specific problem but I had other software related problems until we installed an earlier version of the firmware on the phones. You may want to contact your vendor and see if they can give you a link to an earlier version of the firmware. Unfortunately Polycom doesn't make firmware available on their website like any normal manufacturer, instead you have to go through their authorized vendors :roll: You gotta love that :shock:
    Take care,
  8. LLangston
    Aug 27, 2007
    57
    We use the polycom 501's too and have the same problem with attended or consultive transfers, blind transfers work great. I have a ticket in with polycom about this and will let you know what I find out.
  9. cinghiuz
    Nov 26, 2007
    Hi there,
    as i wrote we have the same problem when try to transfer an incoming call from an analogic/cordless phone, connected to a Linksys PAP2 or PAP2T, to an extension running Counterpath X-Lite.
    After 55 seconds the call drop. I try to do a blind transfer as told by LLangston and it works great also with PAP2/X-lite.
    I tried to contact Linksys support, but they don't give free support for VoIP products, so my workaround is to place on hold the incoming call, call the extension and ask if he want to receive the call, then he hangup and i recall him hanging up the call before he answer, so a blind transfer.
    This works great.
    Thanks to LLangston for his tip ;)
    Cinghiuz
  10. simones181170
    Dec 4, 2007
    51
    i've PAP2 and it works good
    i don't have any droop call when i transfer to the the other cordless phone or to other Ext. ip phone of soft phone
