Transfers failing to external number from external line
Discussion in '3CX Phone System - General' started by alexmex, Jun 19, 2008.
  1. alexmex
    May 7, 2008
    Hi all, I´m using 3CX connected to Mitel switch via SIP trunks and it is working beautiful the scenario is I receive a call from Mitel ISDN lines and then the call is forwarded to 3CX via SIP trunk then the automatic recepcionist answers and if an extension is always forwarded to an external destination, it should go back to MItel and dial the number using MItel lines. It works fine if I call the extension from 3CX extension but from an external line it doesn't. Watching teh logs when I call from the 3CX extension it dials 3005@19.199.1.20 (3CX ip add) but externally it shows 3005@127.0.0.1. The bottom one is the external (unsuccesful) and the top one is internally but still using MItel. I hope it is clear and if you have any clue why is it doing this will be very appreciated.
    Alex
    CM503008]: Call(616): Call is terminated
    16:20:55.521 Line::printEndpointInfo [CM505003]: Provider:[mitel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Mitel-3300-ICP 8.0.9.18] Transport: [sip:19.199.1.20:5060]
    16:20:55.521 CallCtrl::eek:nAnsweredCall [CM503002]: Call(616): Alerting sip:10000@19.199.1.220:5060
    16:20:48.974 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(616): Calling: VoIPline:10000@[Dev:sip:10000@19.199.1.220:5060]
    16:20:48.958 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to "3005"[sip:3005@19.199.1.20]
    16:20:48.958 Extension::printEndpointInfo [CM505001]: Ext.1012: Device info: Device Identified: [Man: Counterpath;Mod: X-Lite;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [X-Lite release 1011s stamp 41150] Transport: [sip:19.199.1.20:5060]
    16:20:48.943 CallCtrl::eek:nIncomingCall [CM503001]: Call(616): Incoming call from Ext.1012 to "3005"[sip:3005@19.199.1.20]
    16:19:54.615 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@19.199.1.20:5060 with contact sip:8888@19.199.1.20:5100;user=phone
    16:19:54.208 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    16:14:25.255 Call::Terminate [CM503008]: Call(615): Call is terminated
    16:14:25.224 Call::Terminate [CM503008]: Call(615): Call is terminated
    16:14:25.193 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10002 forwards to DN:8004
    16:14:15.505 Call::RouteFailed [CM503014]: Call(615): Attempt to reach [sip:3005@127.0.0.1:5060] failed. Reason: Not Found
    16:14:15.505 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(615): No known route to target: [sip:3005@127.0.0.1:5060]
    16:14:15.505 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:3005@127.0.0.1:5060]
  2. alexmex
    May 7, 2008
    It had something to do with the outbond options but it was weird because I have a general and I had to create a new rule for this kind of transfers.
    Thanks anyway
    Alex
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    I've deleted my previous question, sorry for confusing.
    What version of PBX are you using?
    Is outbound rule configured to be used with specific list of extensions?
  4. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Hey alex. Im looking at similar scenario to this. So....you are connecting the ICP 3300 to 3CX as a generic SIP trunk, correct? How hard was the config on the mitel side?
    Also, does extension dialing work back and forth between extensions on the mitel and extension onthe 3cx?
    Thanks.
    Mike
