transfert to the extension with the name
Discussion in 'CRM / Helpdesk / App Integration' started by eripaq, Apr 4, 2016.
  1. eripaq
    Dec 1, 2015
    I'm trying to create a VAD project. I juste want to say by example "john Doe", and I want the system to transfert to his extension, if John doesn't exist go to the mainmenu...
    Please help
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,438
    114
    Hi there,
    Do you want to use Speech Recognition? If that's what you want, currently it's not available out of the box, but it's possible in the following way:
    1) Record audio from caller using a Record component, and save it to a WAV file.
    2) Create a DLL and use the SpeechRecognitionEngine class from Microsoft Speech API to perform the speech recognition from the WAV audio file (http://msdn.microsoft.com/en-us/library ... e(v=vs.110).aspx)
    3) Call that DLL from an External Code Execution component, passing the wav file name as a parameter.
    That way, your voice application can react to user speech.
    Hope the information helps.
    Kind regards.
  3. eripaq
    Dec 1, 2015
    do we need to install something to call dll?
  4. edossantos
    Jun 27, 2007
    1,438
    114
    The SpeechRecognitionEngine class is available in the .NET framework. You need to use Visual Studio to create a DLL and use that class from the DLL.
    Then, from the VAD, you need to use an External Code Execution component to call the DLL you created.
  5. eripaq
    Dec 1, 2015
    Is there any other way, like a third party that we can do speech recognition?
  6. edossantos
    Jun 27, 2007
    1,438
    114
    No, currently it is the only way to go.
