Translation French Manual
Discussion in 'CRM / Helpdesk / App Integration' started by sbsconseil, Dec 14, 2009.
  1. sbsconseil
    Apr 29, 2008
    29
    hi,
    will you translate the manual VAD into French
    will you training VAD
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Training is coming very soon...
    In regards to French, I'm not sure if the manual will be translated or not, this is a development tool, so maybe it remains only in English for some time...
  3. VAD_Support
    Aug 6, 2009
    690
    In regards to VAD training, take a look at http://training.3cx.com/Home/visual-application-designer-1
    Regards,
