Transport=tcp for a VOIP Gateway
Discussion in '3CX Phone System - General' started by Doug, Nov 23, 2007.
  1. Doug
    Nov 22, 2007
    7
    How can I specify that a Gateway uses transport=tcp instead of the default of UDP?
    Thanks.
