I have a Linksys SPA962 and a Cisco 7912G and when you want to transfer a call on the SPA962 you have in the lower right corner a softkey with the tekt transfer. When you press transfer, you get a dialtone, dial an other extension nr, wait for connection, en press transfer again to compleet the transfer, both partys have now a connection and your out of it.
see log:
23:57:44.453 StratLink:
nHangUp [CM104001] Call(30): Ext.114 hung up call; cause: BYE; from IP:172.16.0.254
23:57:40.015 StratLink:
nHangUp [CM004001] Call(30): HangUp from wrong leg has arrived. Leg will be removed from call
23:57:36.015 StratTransfer::finishTransfer [CM108005] Call(30): Transfer finished, Ext.113 is connected to Ext.114
23:57:35.796 StratLink::Transfer [CM104002] Call(30): transfers Ext.113 from Ext.200 to sip:
[email protected]
23:57:31.437 CallLegImpl:
nConnected [CM103001] Call(31): Created audio channel for Ext.114 (172.16.0.254:16446) with Media Server (172.16.0.200:7116)
23:57:31.437 StratInOut:
nConnected [CM104005] Call(31): Setup completed for call from Ext.200 to Ext.114
nConnected [CM103001] Call(31): Created audio channel for Ext.200 (172.16.0.199:16470) with Media Server (172.16.0.200:7114)
23:57:25.765 CallConf:
nProvisional [CM103003] Call(31): Ext.114 is ringing
23:57:25.671 CallConf:
nIncoming [CM103002] Call(31): Incoming call from 200 (Ext.200) to sip:
[email protected]
23:57:20.562 MediaServerReporting::RTPSender [MS004000] Call(30) Ext.200: (ACTIVE): Can't send RTP stream to 0.0.0.0:16468 destination unreachable
23:57:16.671 CallLegImpl:
nConnected [CM103001] Call(30): Created audio channel for Ext.200 (172.16.0.199:16468) with Media Server (172.16.0.200:7112)
23:57:16.671 StratInOut:
nConnected [CM104005] Call(30): Setup completed for call from Ext.113 to Ext.200
nConnected [CM103001] Call(30): Created audio channel for Ext.113 (172.16.0.254:16444) with Media Server (172.16.0.200:7110)
23:57:13.890 CallConf:
nProvisional [CM103003] Call(30): Ext.200 is ringing
23:57:13.781 CallConf:
nIncoming [CM103002] Call(30): Incoming call from 113 (Ext.113) to sip:
[email protected]
when I look on the web page op the phone, tab region, under "Vertical Service Activation Codes", you see the "Blind Transfer Code: = *98"parameter. Maybee it wil work alsoo if you dial *98 to transfer the call, I haven't tried yet.
For the Cisco 7912G you have to press in the lower right corner More to come to the softkey Transfer.
I hope it wil work for you.
Not bad he for a newbee.
Pirkaiia
