Solved Trouble Downloading firmware.
Discussion in '3CX Phone System - General' started by THCO, Oct 2, 2017.
  1. THCO
    May 16, 2017
    56
    11
    I just hooked up a new Yealink CP960 and I am trying to download the new firmware from 3cx. I keep getting a "Unable to reach 3CX Updates server. Check your internet connection and try again." I am running the latest version of 3cx and it is licensed.
    I have a 50mb connection,
    I have tried changing the dns to 8.8.8.8
    I have cleared the browser cache.
    NSLOOKUP is working correctly.
    Firewalls are turned off.
    Time on my windows server is correct.
    The strange thing is I can download everything else from 3cx just fine.
    Not sure what else to check.
  2. THCO
    May 16, 2017
    56
    11
    Well now it just downloaded correctly, This can be marked solved.
  3. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hi @THCO,
    Glad the issue is resolved, and thank you for your feedback :)
  4. david.vanegue
    Dec 18, 2014
    hello. i have the same problem. impossible to download the last firmware for a CP960 and a T58
