Trouble sending calls to "all phones"
Discussion in 'Windows' started by ngiovas, Aug 6, 2010.
  1. ngiovas
    Aug 6, 2010
    14
    I am new to 3cx and am considering switching my entire house and home office to IP phones. I have installed 3cx and have configured the SIP settings for my provider (Viatalk). So far, I have two soft phones working. I am able to make calls from either phone with no issue.
    The problem I am having is that when an inbound call is received, it rings on extension 101, but not extension 100. I created a group 800 called "all phones" and set the inbound rule to send calls to this rule, but only the one phone receives the call.
    Can anyone suggest what I can check to correct this issue?
    Thanks,
    Nick
    ps - I also have a newbie question about using a PSTN interface, but I will create a new topic.
    11,129
    330
    Post the 3CX log of an incoming call.
  3. ngiovas
    Aug 6, 2010
    14
    Thanks. Your request helped me solve my problem. After turning up the logging level, I realized it was using an "after hours" rule to forward inbound calls to port 101. I changed the rule, restarted my soft phones and now both phones ring when there is an inbound call.
    Thanks again for pointing me in the right directions.
  4. leejor
    11,129
    330
    I had responded on your other post, never mind.
