Trouble Setting up 3CX
Discussion in 'Windows' started by fruvous, Jun 9, 2015.
  1. fruvous
    Jun 9, 2015
    Hi all,
    Newbie here so please take it easy :p
    I went through the setup of the system on a Windows Server 2012 R2 Standard VM box. Followed the instructions posted here on how to set up an internal FQDN. When I use NSLookup, it keeps saying that the local domain can't be found. Any idea?
    Other things, it appears that the IP on the VM is the same as my external IP and the DNS currently points to 8.8.8.8 (Google).
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    An external DNS won't resolve an internal FQDN.. seems you have a "network problem" here.
