Trouble upgraded to SP4?
Discussion in '3CX Phone System - General' started by CBUTLER, Dec 13, 2016.
  1. CBUTLER
    May 11, 2015
    52
    Anybody else having trouble upgrading to the latest service pack?
    When I click Download, it immediately kicks me out to the login screen. I log back in a few minutes later and it is still asking me for an update, so I click Download again and then it stays suck on the "Download has started, please wait"
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    18
    Hi, Could you please restart 3CX Event Notification Manager and try again?
  3. michaelholt
    Oct 9, 2015
    21
    You are correct, it kicks you back to the login screen. Eventhough you, the client, are at the login screen, the update is happening in the background. The SP4 update only takes about 5 minutes. Then log back in.
    Another way to do this is to configure notifications to be sent for actions such as the SIP Trunk unregistering and registering. Upon registering then the update is finished.
    I do think this could be programmed better to show feedback of the update process. Ultimately, it should have a bar that fills up when the update is complete.
