Trouble with backlight setting in Yealink phone template
Discussion in '3CX Phone System - General' started by engin411, Jan 5, 2017.
  1. engin411
    engin411 New Member
    Jul 3, 2009
    172
    3CX latest version with Yealink T46G phones. I'm having trouble getting the backlight of the LCD screen to always be on.
    The Yealink template has the setting below. Seems that whether I have the value blank (leaving the default in place) or specify "1" (as I have it below), the backlight turns itself off after a period of time. I haven't timed it exactly, but it seems to turn off after about 6 or 8 hours of inactivity.
    Any ideas on this?
    #Configure the backlight time (in minutes). The valid values are: 1-Always on(default), 60-1min, 120-2min, 300-5min, 600-10min, 1800-30min.
    phone_setting.backlight_time = 1
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,132
    178
    @engin411
    No experience as I prefer the backlight to go off myself. But I can tell you that you will want to go directly to Yealink for support on this. While Yealink is one of the 'preferred' phones with 3CX, any issue I've ever had with a phone or template was deferred to the manufacturer.
  3. cobaltit
    Mar 22, 2012
    1,132
    178
    Just looked through the firmware release notes and saw these entries:
    Code:
    Fixed in x.81.0.20
    Fixed the issue that if phone_setting.backlight_time is set to 0, the phone cannot
    be configured correctly.
    While not the specific issue you are having, may indicate there are other issues with that parameter
  4. engin411
    engin411 New Member
    Jul 3, 2009
    172
    Thanks.
    Does 3CX have a roadmap where firmware updates are listed? How do I know when that firmware will be released by 3CX?
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    It is not recommended by Yealink to turn on backlit permanently, as the display will become pale after sometime.
  6. cobaltit
    Mar 22, 2012
    1,132
    178
    Thanks for the laugh about 3CX and a roadmap :)
    I pulled those notes from the Yealink release notes for the official firmware (not 3CX specific). But as eagle2 mentioned, setting the backlight to always on will eventually burn out the backlit/washout the display.
