Trouble with CallNotifier plugin
Discussion in 'Windows' started by MWFBrad, Aug 11, 2016.
  1. MWFBrad
    Aug 11, 2016
    6
    I'm trying to build a DLL based off this guide:
    http://www.3cx.com/blog/docs/3cxphone-for-windows-api/
    The goal is to launch a program when a call is finished, for now I'm just having it write to a file to show its working (it doesn't). Now I've followed all the steps in the above link, and it does not appear that 3CX is using my DLL. I don't see any smoking gun in the logs, and at this point I'm out of ideas.
    config file:
    http://pastebin.com/yV3TjUX0
    DLL code:
    http://pastebin.com/62HsFchx
    Logs:
    http://pastebin.com/2963AyZt
    the DLL is sitting in C:\ProgramData\3CXPhone for Windows\PhoneApp
  2. Tertius
    Feb 24, 2016
    43
    Do you get any exceptions?
    Try something like this:
    Code:
            private void callHandler_OnMyPhoneStatusChanged(object sender, MyPhonePlugins.MyPhoneStatus status)
                if (callInfo.State == CallState.Ended)
                    string filePath = @"C:/Status.txt";
                    using (StreamWriter writer = new StreamWriter(filePath, true))
                        writer.WriteLine(callInfo.State);
  3. MWFBrad
    Aug 11, 2016
    6
    Just tried that, no change and nothing in the logs that looks interesting.
  4. Tertius
    Feb 24, 2016
    43
    Ensure you are using the correct Framework, 4.0. See Attachment.
    Also, make use of try catch blocks in your code. Catch any exceptions and write to text file - like this:
    Code:
    private MyCRMPlugin(MyPhonePlugins.IMyPhoneCallHandler callHandler)
                try
                    this.callHandler = callHandler;
                    callHandler.OnCallStatusChanged += new MyPhonePlugins.CallInfoHandler(callHandler_OnCallStatusChanged);
                    callHandler.OnMyPhoneStatusChanged += new MyPhonePlugins.MyPhoneStatusHandler(callHandler_OnMyPhoneStatusChanged);
                catch (Exception ex)
                    string filePath = @"C:/Error.txt";
                        writer.WriteLine(DateTime.Now + Environment.NewLine + "Message: " + ex.ToString() + Environment.NewLine + "Stack Trace: " + ex.StackTrace);
  5. MWFBrad
    Aug 11, 2016
    6
    I tried that. No luck, No Exceptions.
    Here's the code now: http://pastebin.com/DVLWvHbf
  6. MWFBrad
    Aug 11, 2016
    6
    Quick update,
    I'm still trying to find a solution for this problem,
    At this point I've tried reinstalling 3cx on my computer, running it in administrator mode, replacing the file writing with launching an executable, and using the 3CX CRM template to create a new one from scratch.
    No luck, nothing works. If anyone has any ideas, I'm all ears.
  7. Tertius
    Feb 24, 2016
    43
    1. Is your 3CX license edition PRO/Enterprise? This is a requirement for the Phone API.
    2. What OS are you working on?
  8. MWFBrad
    Aug 11, 2016
    6
    We are using a Pro license, and I am running Windows 10 Pro.
  9. Tertius
    Feb 24, 2016
    43
    Hello again,
    I just replicated your DLL and ran it in our environment. It worked as it should. I used your first pastebin DLL post.
    I'm also using Windows 10, version 1511, OS Build 10586.545
    It sounds like you were quite meticulous of the setup of your DLL and following the documentation closely, therefore I would suggest you look at your environment. Your DLL is fine.
    Good Luck!
  10. antyxsoft
    Feb 12, 2015
    You should add a new line in the 3CXWin8Phone.user.config (the one with key="CRMPlugin") only if it does NOT exist.
    If such a line there is already there, then just add your plugin by appending a comma and the file name of your plugin .dll (without the .dll).
    E.g
    <add key="CRMPlugin" value="Plugin1,Plugin2,Plugin3,YourPlugin" />
    Theo
  11. Tertius
    Feb 24, 2016
    43
    He has already done this. Check his 1st post, the Config File pastebin link.
  12. MWFBrad
    Aug 11, 2016
    6
    Thats it!! Once I deleted the other CRMPlugin Line, it worked. Oh wow, thank you. I had a fairly large project hanging on getting this working, and was really feeling the pressure, thank you so much.
  13. antyxsoft
    Feb 12, 2015
    Glad to hear it.
    Theo.
