Trouble with outbound calls
Discussion in '3CX Phone System - General' started by edwards2020, Nov 13, 2009.
  1. edwards2020
    Nov 13, 2009
    I am trying to place outbound calls from a SIP client on my IPhone to external numbers. We are trying the free version with the possiblity of purchasing it.
    I am able to dial into the SIP client from a land/cell line; however, I am not able to dial out. I've configured outbound rules and believe that I've gone throught all of the setup steps properly. I temporarily turned off the firewall to see if this was the issue to no avail.
    I am using Bandwidth.com as the PTSN. Here is what I'm seeing in the logs. (The x's aren't the log - just blocking out the cell number.
    09:43:51.203 [CM503008]: Call(32): Call is terminated
    09:43:51.156 [CM503020]: Normal call termination. Reason: Not found
    09:43:51.156 [CM503016]: Call(32): Attempt to reach <sip:xxxxxxx@istphones.gotdns.com> failed. Reason: Not Found
    09:43:51.156 [CM503014]: Call(32): No known route to target: <sip:xxxxxxx@istphones.gotdns.com>
    09:43:51.156 [CM503010]: Making route(s) to <sip:xxxxxxx@istphones.gotdns.com>
    09:43:51.156 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SipPhone v3.0/iPhoneOS] PBX contact: [sip:100@70.90.194.195:5060]
    09:43:51.156 [CM503001]: Call(32): Incoming call from Ext.100 to <sip:xxxxxxx@istphones.gotdns.com>
    Any help would be greatly appreciated!!
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Looks like a DNS issue, it cant find the host you are trying to reach.
  3. edwards2020
    Nov 13, 2009
    OK, I don't understand.... I can ping the server from on external source using complete different DNS servers. Here's what I get...
    Pinging istphones.gotdns.com [70.90.194.195] with 32 bytes of data:
    Reply from 70.90.194.195: bytes=32 time=20ms TTL=124
    Reply from 70.90.194.195: bytes=32 time=18ms TTL=124
    Reply from 70.90.194.195: bytes=32 time=28ms TTL=124
    Ping statistics for 70.90.194.195:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 18ms, Maximum = 28ms, Average = 21ms
    It seems that the server to trying to connect to external cell phone number @istphones.gotdns.com. Is that correct? Should it be doing that? Inbound calls come from a different IP address.
  4. KerryG
    Jun 19, 2009
    960
    I dont know, is that the server information that Bandwidth.com gave you? I wouldn't think that Bandwidth.com would use a dynamic DNS server for their SIP trunks.
  5. edwards2020
    Nov 13, 2009
    OK, remember. I'm new at this.
    Istphones.gotdns.com is a dynamic DNS entry for my local 3CX box. I have Bandwidth.com setup as a VOIP provider. I don't understand how the sip client is supposed to get to the outside world. When I am dialing an outside line the log says sip:xxxxxx@istphones.gotdns.com which which makes me think it is trying to find this number on my server. It should be routing out to bandwidth.coms server. Right? How do I make that happen?
  6. KerryG
    Jun 19, 2009
    960
    First off, use a softphone on the local network as the PBX instead of a SIP client on the iPhone. This will help eliminate variables. However, since I have no idea what your outbound trunk or outbound rules look like, I can't begin to guess what is wrong.
  7. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Specify the number format you are trying to dial (replace the last 4 digits with X not all)
    How did you configure the outbound rule to go out. Not found means that bandwidth.com cannot route this number.
    Either you are missing a Plus, or you are stripping the incorrect number of digits - put a screenshot of the outbound rule.
    You can do a very quick test - get a 3CXphone, register it directly with bandwidth.com (bypassing the pbx) and dial this number. If you get a not found in this case as well, the answer is pretty straight forward.
  8. leejor
    10,758
    286
    So, let me get this straight, you are truing to dial into the 3CX from any land/cell phone (not a 3Cx extension) and then get dial tone and dial back out again? Or.... are you trying to dial in and be forwarded to a specific number? Or ...are you trying to register a SIP client as a 3Cx extension and then dial outbound calls from the PBX to various numbers?
  9. robhazes
    Apr 22, 2009
    24
    I am having a similar problem.
    I am using Linksys PAP2 as an external extension, logged in on my 3cx-system.
    I can call to my PAP2-phone, for instance from another external softphone connected to the same 3cx-system, all ok.
    Making a call the other way does not work. I can not call from my PAP2, neither to another internal phone nor to an external phone.
    The IP-address of the 3cx system is dynamic, so I use dynamic DNS to be able to find my 3cx-system. This works fine, my PAP2 always registers with the 3cx-system.
    The error message at the 3cx-side is:
    Unidentified incoming call. Review INVITE and adjust source identification. etc
    When I in "Line 1" section in the PAP2 change the Proxy-field from mydynamicdns.XXX (my dynamic DNS placeholder) to the actual IP address of the 3cx system it all works.
    Anyone who can tell me what to change to make this work with mydynamicdns.XXX in the Proxy-field of the PAP2?
  10. leejor
    10,758
    286
    Ok, first make sure you have STUN enabled on the remote PAP2, this is a given for any remote extension. Since putting in the actual IP of the 3CX works, then I'm going to assume, that the PAP2 isn't able to resolve the DynDNS address of the 3Cx location. In the settings for the PAP2 there is a place (or two) to put in DNS server info. This can normally just be the IP of the local router that will then pass the request on to the DNS server(s) that it "knows" about via the ISP. You might try getting the IPs of a couple of DNS servers and "manually" put them into the PAP2.
  11. robhazes
    Apr 22, 2009
    24
    Thanks for the answer.
    I do not think this is the problem. The PAP2 does find the 3cx system, also with the dynamic DNS placeholder. My 3cx-system registers the call I try to make, but rejects it, see log below.
    Below som log-data from my 3cx system, first the call in the working direction, and then a call in opposite direction which fails.
    Global IP-address 66.166.166.55 and dynamic DNS placeholder mydynamicdns.XXX have been modified for safety-reasons.
    This call from remote internal 14 (3cx softphone) to remote internal 16 (analog phone on PAP2) works:
    23:58:24.375 [CM503008]: Call(64): Call is terminated
    23:58:24.359 [CM503008]: Call(64): Call is terminated
    23:58:22.625 [CM503007]: Call(64): Device joined: sip:16@66.166.166.55:51242
    23:58:22.609 [CM503007]: Call(64): Device joined: sip:14@127.0.0.1:56196;rinstance=e988eaedb8ffe0df
    23:58:14.390 [CM503024]: Call(64): Calling Ext:Ext.16@[Dev:sip:16@66.166.166.55:51242]
    23:58:14.171 [CM503004]: Call(64): Route 1: Ext:Ext.16@[Dev:sip:16@66.166.166.55:51242]
    23:58:14.140 [CM503001]: Call(64): Incoming call from Ext.14 to <sip:16@10.0.0.10:5060>
    This call in opposite direction fails:
    00:00:21.468 [CM503008]: Call(65): Call is terminated
    00:00:21.468 [CM502001]: Source info: From: "16"<sip:16@mydynamicdns.XXX>;tag=2dfbf6c3f613605co0<sip:14@mydynamicdns.XXX>
    00:00:21.468 [CM503013]: Call(65): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 14@mydynamicdns.XXX tid=-cb78e2b9 cseq=INVITE contact=16@66.166.166.55:51242 / 102 from(wire)
    00:00:21.250 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:14@mydynamicdns.XXX SIP/2.0
    Via: SIP/2.0/UDP 66.166.166.55:51242;branch=z9hG4bK-2e1c7245;rport=51242
    Max-Forwards: 70
    Contact: "16"<sip:16@66.166.166.55:51242>
    To: <sip:14@mydynamicdns.XXX>
    Call-ID: ec4f780f-225eef80@192.168.2.10
    CSeq: 101 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Supported: x-sipura, replaces
    User-Agent: Linksys/PAP2T-5.1.6(LS)
    Content-Length: 0
    00:00:21.250 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 14@mydynamicdns.XXX tid=-2e1c7245 cseq=INVITE contact=16@66.166.166.55:51242 / 101 from(wire)
    Hope this might help to find out where the problem lies.
  12. leejor
    10,758
    286
    Ok, I'm a bit confused. This led me to believe that the extension wasn't working unless you put the actual IP (of the 3CX location) in the setting. But then you said...
    So which is it, did you fix that problem??
    As far as the outgoing calls failing. They should not be trying to go out to anything at Istphones.gotdns.com if your VoIP provider is at Bandwidth.com. I'm assuming that the trunk that you have created to Bandwidth.com is showing as registered?
    It sounds like you haven't created a valid outbound rule to route the call (based on your dialled digits) to the trunk at Bandwidth.com. Since you've X'd out all the numbers I have no idea what digits you are sending 3CX or what you want to go out on the trunk. If you post another log, just X out the last couple of digits of the phone number.
  13. robhazes
    Apr 22, 2009
    24
    leejor:
    Please check member-name of the posts. There are 2 different problems mentioned in this thread, it seems you are mixing the problems...
    My problem is not fixed. Please check error log in previous post. Hope you have some advice...
  14. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Two log messages in your post:
    first
    and second
    provide hints for you.
  15. leejor
    10,758
    286
    Sorry, my mistake.
  16. robhazes
    Apr 22, 2009
    24
    Thanks Stepan. I have been trying to understand at which side to make changes, but have not succeeded. My best guess is I have to make a change somewhere in the 3cx setup. Any suggestions?
  17. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HI Rob,
    Try and avoid posting problems in threads which are being used to diagnose another users issue, please open a new thread people will surely assist you that way.
    So in regard to you rob please see this video, the last minute and a half is the part that you need to look at.
    http://www.3cx.com/docs/manual/sip-trunks/ - Updated link
  18. robhazes
    Apr 22, 2009
    24
    No problem, I start a new thread next time. This one seemed to be dead, and the problem was similar, thats why...
    I had a look at the video, but it does not really help. I checked the 3CX doc as well without results. Hope someone can suggest the solution for this problem.
