Troubles to "Build" with 3CX VAD
Discussion in 'CRM / Helpdesk / App Integration' started by arriatj, Jun 10, 2015.
  1. arriatj
    Jun 10, 2015
    I just created a new project with 3cx VAD and when i do :
    a “Build”=>”Debug Build” no problems, but when i try to build it with : “Build”=>”Deploy”, got some troubles. A window "Upload" opens and when I arrive to a ".vxml", the uploading stop and nothing happens after...
    Do you have any solutions that would allow me to deploy this project in "debug mode" ?
    Thanks.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there!
    Are you trying to deploy locally in the same 3CX server? Or from a remote computer?
    If you deploy from a remote computer, you need to allow remote access to the configuration as explained in the users manual.
    Kind regards.
  3. arriatj
    Jun 10, 2015
    Hello again,
    I'm trying to deploy it locally, so it's not about remote access...
    Any other idea ?
    Kind regards.
  4. arriatj
    Jun 10, 2015
    Ok ok ! Found my mistake !
    I was about the version of the PBX on "Tool" => "Options" => "Projects"... I was on v11 instead of v12.5 !
    Thanks again for the support .
