True Caller integration to identify junk callers
Discussion in 'Ideas' started by jj1, Jun 22, 2016.
  1. jj1
    jj1
    Feb 23, 2012
    24
    I have used True Caller on my smartphone for a couple of years and it is great at helping identify junk callers. Any chance that 3CX can provide similar functionality/integration even if only through the 3CX desktop client. I assume that it would just need to do a quick number lookup to tag the callers name/description.
    Danielkg likes this.
